i have an r32 skyline its a four door factory auto that has been converted to manual and had a reco engine put in it (not original motor)
my mods are
fuel reg
pump (walbro)
gtr fmic
pod
supersparks
they are the important ones anyways
my problem is the engine is detonating and the car smells really fuelly more than an averge rb20de i have replaced the fuel line going to the filter aswell as the one after filter going towards the front of the engine the others look preety good and i have changed the fuel filter and its still happenig i have cleaned and check the gap on the plugs and all seems fine im thinking it is a leakin injector or something is there any way of testing them with out take them out and without using a noid light... also does any one have a pic on how the standard CAS sits mine is pulled hard right (as in the elongated holes that allow timing adjustment are not centered and the bolts are on the far left of the hole and it doesnt seem right) and i think i may have to much timing going in because the bolts dont line up with the marks on the CAS so its suspect
Thanks for any help
Cheers Bejay
https://www.sau.com.au/forums/topic/343071-detonation-help/
yeah i will check the timing tommoro and why do i have to put the stock reg you think its dodgy? also i dont have a consult but i can bridge the pins to check for error codes ...
do you think it is safe to drive its my daily i need it for work
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5532878
just looked at ecu to make sure it is a standard one...
its not its a nasty tomie stage one
which has timing and ignition maps all tinkerd with
no fuel or speed cut
no boost cut
and also tuned
for boost up aswell
as exauhst
cooler pump etc
i had a mines in my last 32 and had nothing but issuse with it i think this may something to do with it cause ther cheaply made and the agressiveness of the fuel and ignition maps also my car is on stock boost also so dont no if that helps
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5534021
yuck, those jap remaps are pretty terrible, 10:1 fuel ratios and shitloads of timing, not good with our fuel or climate, had a car with a mines ECU that wouldn't rev over 5.5k due to rich misfire as it was running below 9:1 fuel.
Definitely get it to a tuner and on the dyno, i recommend a nistune for how cheap and easy to tune they are, also they look stock.
Edited by Rolls
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5534033
If it is actually detonating it sounds like a fuelling issue, stock ECU should pull back timing loads if you've increased the boost (exhaust + fmic will do this).
Can you confirm fuel rail pressure, pump making any funny noises? Really need to get it on the dyno as detonation can kill a motor pretty quick.
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5535636
i am running 11psi due to exaust and frountmount with no controller and i bought the car just over a week ago with all mods fitted i have not changed anything since purchace just put fuel in and i dindt seem to do this the day i got it so ine been riped or unlucky as...
i think its a fueling issue aswell now because my ideal has become irratic and will not hold steady on idle the car drops from 800 down to 400 randomly and also on idle the engine seems to have an exauhst pop it sounds like it has a standalone ecu in it is so irratic which makes me think its fuel or timing doing so only thing i change was the fuel filter and i changed the the fuel pressure from 20psi at idle to 32 psi which did not make a difference...
do i have to completly disconnect the aftermarket reg(like take the fuel lines off and have it not hooked up at all) or can i just swap the vac line from the aftermarket back to standard...
also i noticed on the gague on the reg the fuel pressure will not stay at 32 psi as the idle pops and drops so does fuel whicmh makes me thinks its a fuelling issue and pump doesnt seem to make any differnce
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5536292
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5536308
base fuel pressure for the RB20 is 35-40psi. so at 32psi your just under that which may cause issues, but at 20psi it definitely will, no wonder it was pinging.
i know you didn't install and setup the aftermarket regulator but are you saying that you have both the stock reg and the aftermarket one attached to the fuel line? it should be one or the other, not both. can you post up a pic of your fuel reg setup? oh and to disconnect the aftermarket reg you have to pull the fuel lines off as well as the vac line.
Edited by QWK32
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5536315
yeah the stock reg was still attached but no vac line going to it
the after market reg is set up on the return line just after the reg on the rail above thermo stat housing if that makes sense will have a photo buy tonight
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5536325
pull the aftermarket reg off, put the vac line on the stocker and see if it runs. if not the stocker is probably drilled out, if it does run and works then whoever set it up like that is slightly retarded, as no vac line on the stocker will mean higher than factory pressure whilst in vacuum.
put it all back to factory and see if it solves your problem
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5536537
Shouldn't be changing ANYTHING to do with a fuel reg if you are running a stock ecu, any change will completely f**k up the tune.
Put it al back 100% to stock or get a full tune, there are no other options.
i have put the stocker ecu in and hooked up my stock reg and my pingin has gone
i will get the reg checked and make sure she works before i think about putting it back on thanks guys...
one last thing what boost will the stock reg put up with before it starts to fail???
https://www.sau.com.au/forums/topic/343071-detonation-help/#findComment-5538553
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
