  • Replies 181
Brodie,
1. Rear Windscreen Wiper with all the bits including the Black Cover on top and Black Cover inside boot + 2 x white clips to anchor it - still have? Cost to post to Melbourne please?
2. 6 x GTR CoilPacks - still have? How much please?
What colour is the car? Condition of front Bonnet?
Les . . .
Bodie.
1. Rear Windscreen Wiper including black plastic top cover + black plastic bottom cover over motor + 2 white plastic clips for bottom cover - got it all mate?
2. CoilPacks x 6 - got them and how much?
Les . . .
Do you have rear hubs ?
hey mate! yeah i do and i have half shafts if ur still hunting them too, i forgot to reply to ur PM the other day sorry!
front pipes $100
sunvisors $20 each
interior mirror $20
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60
heaterbox/ all under dash make an offer
rb26 cam/timing belt cover $70
speedo 140,xxxk's $50
brake calipers x 4, $300
intercooler mesh $30
trust pod filters x 2, $80
monster tacho with shift light $50
steering wheel $50
GTR fuel pump exc. working order $100
glovebox $30
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $40
side mirrors $50 each
bonnet squirters $20 pair
bonnet heatshield $60
A,B,C pillars
clutch master $40
brake booster $60
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150
metal plate that goes inbetween rear seat and boot $60
windscreen wipers $30 pair
window wiper motor $40
overflow and washer bottles
kickpanels $20 each
assorted cooler piping from gtr $50
wheelnuts $25
have all seatbelts except drivers side
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $40
turbo timer exc. working order $30
handbrake $30
random 8 inch subwoofer never been used $20
there's heaps more! the whole underside of the car is still there! diff, half shafts, hubs, the lot!
anything u can think of i would bet i have it, just ask away pics coming
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
