Hi all, im selling parts from a R32 GTR and GTST both are 92 models.
i brought a damaged GTR for the motor and parts to put into my GTST but not long after getting all geard up to do the swap of parts GTST got writen off, so my lose could be ur gain,
parts 4 sale
GTR parts,
Nismo 320 cluster has 92,xxxkm on clock $350, gearbox $700, front and rear brakes setups hub rotors and calapers $550, rear diff k frame and all$500( top control arms bent on passanger side), rear seats $100, dash airvents $50 each, rear window $150, both rear quater windows $80 each all glass has tint on them, front R/H light and blinker $50, rear R/H brake light $50, passanger door with window $200 have a set of coil overs not sure brand but one of the rear ones r bent on the shock part but can be replaced all rest are fine $800, any other parts just ask as i may still have them. parts sold motor, front seats, drivers door and glass, front gards,
GTST parts,
Rb20 motor and box 130,xxxkm, extrem button clutch, hks bov, standed turbo off RB25, (no ecu got damaged) $1200, both rear lights $100, headlights blinkers $100, all interior in great condition start from $50 up to $150, all glass except front window and drivers window$50 to $150, rear bar $60, boot lid $80, doors drivers $100, passangers $150, lowered springs and shocks $200, brakes to brakes on diff $350, intercooler and piping for rb20 $200, other parts that havent listed but it was a full car so all still there.
i live south perth so any parts that need posting will be at buyers expence,
will up load photos next week of all parts and conditions
contact me on 0437117758
https://www.sau.com.au/forums/topic/343172-r32-parts-for-sale/
I'm after an R32 GTR AAC Valve. You have one?
Also R32 GTR centre console surround / facia.
Les . . .
__________
parts 4 sale
GTR parts,
GTST parts,
sorry guys it wont let me pm anyone,
lonewolf1983, sorry man gtr bar got smashed wen chick crashed it,
Boz soljah, have rear pods off gtst but only drivers side skirt passanger one got cracked,
ben3322, i dnt have standard steering wheel i only have boss kit and sports wheels on both r32s,
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
