  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
WHY? What'd you do to lauren! :)
Erin ive just been down lately and i TOLD paul might be nice if he dropped me an email or something to cheer me up - which he didnt do n just decided to do the opposite n be more insensetive which didnt help the situation.
But its ok - ive got some really good friends :D
But at the moment he's gonig around trying to play the sympathy card off everyone.
Ben .... i just give up not worth me stressing over :D i just know better who to run too when im down now :)
Anyway said wasnt going to discuss this - i just hate it when im painted as the bad guy and its not my fault and being accused of not making it clear .... how clear can i made it "im feeling depressed ... send me an email to cheer me up you havent bothered to contact me in a while"
Adrian, I've been sent some data scans by the guy that developed the software...and it looks brilliant...every facet of the ECU can be looked at...all sensor outputs can be seen.
Also has a few super-secret tricks they use at dealerships....with rumoured possibility of remapping the factory ECU (with slight modding) :D This thing could be dangerous.
Mwahahahaha...imagine eliminating the need for a power FC!!!!
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
