Never allow a telephone conversation with a woman to go on longer than you are able to have sex with her. Keep a stopwatch by the phone. Hang up if necessary.
ok thats just a little strange & I really don't get that one :Oops: so explain please
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
The wife coyly tried to explain her purchase of a new pair of expensive imported panties. "After all, dear," she said to her husband, "you wouldn't expect to find fine perfume in a cheap bottle, would you?"
"No," her husband replied. "Nor would I expect to find gift wrapping on a dead beaver."
This married couple were on holiday in Jamaica, and were walking around the
market place browsing at all the goods for sale, when they passed this small
sandal shop.
>From inside the shop they heard the shopkeeper in his broad Jamaican accent
say "You foreigners! Come in. Come into my humble shop." So the couple
entered. The Jamaican said to them "I have some very special sandals. I tink
dat you would be interested in dem. Dey make you wild at sex."
Well of course the wife was really interested in buying the sandals after
hearing the mans claims, but the husband felt he didn't really need them, as
he was such a fantastic sex God.
The husband asked the Jamaican " How could the sandals make you into this
sex superman?"
The Jamaican replied "just try dem on man". Well the husband after some
badgering from his wife finally gave in and tried the sandals on.
As soon as he slipped them onto his feet, he got this wild look in his eyes,
something his wife had not seen in years! The husband grabbed the Jamaican,
violently bent him over the shop counter, yanked down his shorts and pants,
ripped down his own pants, and grabbed a firm hold of the Jamaican's hips.
The Jamaican suddenly began screaming , " YOU GOT DEM ON DE WRONG FEET
mmmmm was trying to find out where the smell was coming from paul :throwup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
