  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
OI Ben Please dont install or change anything, I had to try to explain to my boss how come i had to spend 3 hours formating that new PC to take home to replace the other one.
I'm not blaming you, just a warning that's all :) if it happens again = no ADSL at home for anyone, inc me :D
Wait... You're saying that if chaos ****s another computer, you get kicked off the net forever? As well as him?
Go ben go! I will give you lots of links for stuff to install! LOTS OF STUFF! HEAPS OF IT! MANY MANY PROGRAMS GUARANTEED TO FUX0R YOUR BOX!
*gigglecopter*
:) I'll still have the net here at work, that wont change, my boss was just not happy that I had to waste 3 hours of the companies time fixing a company computer I had at home.
Because I have a lappie now, it was hard pressed to get another crappa pc to take home.
That computer has been running fine for ages until someone started installing crap on it, and I know it was not me. That leaves only 3 other people who use it. I know who it was, she is just too stupid for words, really!
yup i noticed it on wednesday when i got home. Something just above the task bar.
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
