  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
how hard are they to fit Adrian?
Ummm I bought a complete cluster with them already fitted... So cant comment completely...
BUT... The cluster I bought had a fux0red speedo (probably because the guy who did fit them f**ked up) so I had to replace his speedo, with my speedo...
All I can suggest is be VERY gentle, and be extra careful of the needles...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
