I don't get it<
even if you did move em, couldn't you put em back on zero before you re install them?
I had the old style EL dash where you HAD! to remove the neddles to put them on , Very! tricky . If you have the new style where there is a bigger hole in the centre they can slide right over the neddle without having to touch them, MUCH ! MUCH ! better option , if you have the old style tell me and I may be able to help
old : small hole and anolog dial
new :big hole (about a 10c piece) and a digital touch type dial
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
That dont matter only n00bs type F5 all the l337 h4x0rs know it should be f5 and type that accordingly, n00bs!
Driftorie lite 1 , Mr "I was using my hand brake and it still won't slide" 0
Im not sure which ones?
will find out tomorrow I suppose.
If I have to pull em apart I'll get your help.
Yes I need practise cause I SUCK TOTALLY AND UTTERLY at drifting, so I am going to get more practise, still is Mr. "Doriftor Eliete" coming to the next drift day at QR like me?????
so is some one getting any thing under way fotr tomorrow night??? looking at Mr Mud & cyrus
Dont look at me, I have done my 1 cruise this week already :P
Anyway I am doing a parenting course that will run every second thursday night finishing bout 9:30pm and by that time you guys are already off gallavanting around the country side and now with no mobile it makes it hard to track you down, so meh I'll be a no show tomorrow if there is anything on.
hey cyrus I am looking into getting a new phone if ur keen I will be selling my old one for say $50 or a slab of bundy rum & colas comes with car kit & home charger & new 2nd battery
Yeah sounds good, what is it?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
