  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
It was going good till I just went out and bought subway. First of all they lost my fax order.. second of all they put off cucumber on it. It tasted aweful!! I should ring and whinge.
are u joking hell yeah ring & tear heads off they always going on how there food is fresh & every thing I would be on the phone already erin free food coming up :rant:
Hell yeah Gordo! You get a free cookie if you fax your order :rant:
Plus it's easy to fax it, leave work drive there, walk to the register and it's all done. Walk out again and be back at work within like 15 minutes.
Cept today my order was sitting oon the floor and they didn't see it. If I could I'd email it :rant:
Subways crap thats no secret - reason why jarrod lost so much weight eating it is probably cos he got food poisoning off it. One subway i went to had flies sitting on all the meats etc - didnt eat it after that!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
