  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hay there peeps :wavey: man it has been quiet again latley, 5 days of posts on one whoretown page , these are sad days my friends sad days.
P.S welcome Stomp :wavey:
PPS I just moved my number plate from my front grill to my lower drivers side vent ............................just letting you know ? ....................I'm an idiot!
I'm so tired of being with you
Supressed by all my childish fears
And if you have to leave
I wish that you would just leave
Cause your prescense still lingers here
And it won't leave me alone
These wounds wont seem to heal
This pain is just too real
Theres just too much that time can not erase
When you cried I'd
Wipe away all your tears
When you screamed I'd
Fight away all your fears
When I held your hand through all of these years
But you still have
All of me
When you cried I'd
But you still have
All of me
hey erin how you??
feeling alright there :P
You used to captivate me
By your resonating mind
Now I'm bound by
The life you left behind
Your face it haunts
My once pleasant dreams
Your voice has chased away
All the sanity in me
These wounds won't seem to heal
There's just too much that time cannot erase
When you cried I'd
Wipe away all of your tears
When you'd scream I'd
Fight away all of your fears
But you still have...
All of me.
I tried so hard to tell myself that you're gone
But though you're still with me
I've been alone all along
When you cried I'd
All of me.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
