er..maybe .. it will have a fair few photos. I am planning on it being fully dynamic back end content, mysql database, etc - but to start with to get it up i might just use flat html.
I am going to put a whole bunch of tutorials up for all the stuff i am doing, such as changing the brakes to mspec, compliancing, etc.. eventually the manual conversion, and engine drop in, lada.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
mate's cable tv box and cable modem got lightning striked a while ago..
it also scrooed up the pc onboard ethernet and mobo..
definitely turn things off and unplug
*strutto liked to be probed by dictionary.com* :P
that requires tools... even power tools..
oh well, if all my equipment gets blow up and / or myself.. I'll just sue TPG saying that they had a "duty of care" to inform me that lightning was dangerous, and come over and disconnect my internet and all appliances for me.. and that even though I am the stupid one, its their fault that I am stupid.. I will walk away with millions.
I hears its the latest lawyer bullshit these days, can't go wrong..
hey, how much cutting of a stock R32 front bar do you have to do Will in your car ?? I was getting most of the front bar off yesterday, and there wasn't a hell of a lot of room in there.. Or did you go for a GTR cooler?
think i have worked out a deal on some piping for the cooler i have :P I love the internet..
back in the old days I had 600x250x75mm fine/tube and big ass endtanks fit in the front bar with a bit of cutting.. mainly lower part (and both side intakes) trim down to almost just skin.. top part near bumper reinforce bar isn't touched..
ok.. yeah, thats about the same size cooler that is to go in mine.
I was thinking of even getting a spare reinfocement, and just cutting that.. seems a waste to hack apart a perfectly good support.
Horn and things could be a problem.. about the only mod my car appears to have is crazy japanes eairhorns.. unfortunately they don't appear to be working :P
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
