no, but this is the same car your thinking of. Was built there. Went in N/a manual, came out in mainy stages. ened up with 600hp of fun.
Sold the car to in dude in WA.
ahh i do remember a blue s13 when i was there a few years ago. had a 20 in a the time and was looking at a 25. couple of nice skylines as well with those guys.
you might remember my car. purple strawberry face 180sx. with the IVS stickers all over it.
will be doing the conversion in my garage as well. engine built off site though. dont think i have the tools to torque hone and balance all the components and tune the ecu.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeah... all my engine work is done by a 3rd party :)
when i get the $$ i'll be doing the strawberry on my 13.... 1315's look nice i reckon !
yeah i will be changing over to strawberry face again after the nose was written off by my bad driving. did see a kit for the s13 with 240z nose.. that was cool
so what parts going in if you dont mind me asking?
i got some forged pistons, h beam rods, balancing and crack testing the crank and block. DE head, Garrett GT30R (or 35R not too sure yet) and 100hp shot of wet nos.
only a rb20 atm... my sr died a horrible death and i need to get it on the road... so fairly std atm :) need it for work... I did have a 26crank/rods and some 82 mm pistons to go into it... but sold em to get the $$
My Mobile: 1900 ska luv (edit) :)
But I'll prolly be as lost as you, but yeah I have erins mobile so wont get too lost hopefully :D
sweet thanks mate... if you get someone called ed... or sarah (gf) callin.. it's me lol
20's are cool. geez they take some punnishment though and still end up alright.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
