  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I dont mind, I love prank calls, but they never end up telling me what colour undies they are wearing for some reason? :confused: :)
right.. will get my sister to call you then. from what i hear she dont wear undies
