  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ed dont feel so bad.. at least u don't have coolant pissed out on the ground for no reason :(
just as well I wasnt planning to drive anywhere in the pos
haha will... i thought it was all good ? what did you bust ? a heater hose ?
glad you got that cap to putt around in :P
glad you got that cap to putt around in :(
not sure yet as I didn't know coolant leaked till few hrs after short drive and saw the wet ground..and then I rather sit in the aircon room than garage.. :P
yeah the 3cyl powah was a bit of impulse buying thing but at least its a little different ;) can't wait to make it a bit faster :D
bah u should'v turn off/unplug/smash the emergency extension fone :(
it was funny at werk yesterday, idiots rang the oncall just before 12 for spastic email client related.. little do they know no one is in the office and nothing will be done till next yr :P
well the rb20 is getting fixed up (blew a coolant/heater hose) for the 3rd time. caught it before the engine went pop. hopefully i will clean it all up for the WA transport department inpection to transfer to wa plates (noooo loose the qld plates sniff) then give a few fun runs around town then put it up on jacks... it has to be finished by october 1 next year for a mates wedding. will be doing cerimonial donuts insted of confetti
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
