  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ed dont feel so bad.. at least u don't have coolant pissed out on the ground for no reason :(
just as well I wasnt planning to drive anywhere in the pos
haha will... i thought it was all good ? what did you bust ? a heater hose ?
glad you got that cap to putt around in :P
glad you got that cap to putt around in :(
not sure yet as I didn't know coolant leaked till few hrs after short drive and saw the wet ground..and then I rather sit in the aircon room than garage.. :P
yeah the 3cyl powah was a bit of impulse buying thing but at least its a little different ;) can't wait to make it a bit faster :D
bah u should'v turn off/unplug/smash the emergency extension fone :(
it was funny at werk yesterday, idiots rang the oncall just before 12 for spastic email client related.. little do they know no one is in the office and nothing will be done till next yr :P
well the rb20 is getting fixed up (blew a coolant/heater hose) for the 3rd time. caught it before the engine went pop. hopefully i will clean it all up for the WA transport department inpection to transfer to wa plates (noooo loose the qld plates sniff) then give a few fun runs around town then put it up on jacks... it has to be finished by october 1 next year for a mates wedding. will be doing cerimonial donuts insted of confetti
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
