  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ed dont feel so bad.. at least u don't have coolant pissed out on the ground for no reason :(
just as well I wasnt planning to drive anywhere in the pos
haha will... i thought it was all good ? what did you bust ? a heater hose ?
glad you got that cap to putt around in :P
glad you got that cap to putt around in :(
not sure yet as I didn't know coolant leaked till few hrs after short drive and saw the wet ground..and then I rather sit in the aircon room than garage.. :P
yeah the 3cyl powah was a bit of impulse buying thing but at least its a little different ;) can't wait to make it a bit faster :D
bah u should'v turn off/unplug/smash the emergency extension fone :(
it was funny at werk yesterday, idiots rang the oncall just before 12 for spastic email client related.. little do they know no one is in the office and nothing will be done till next yr :P
well the rb20 is getting fixed up (blew a coolant/heater hose) for the 3rd time. caught it before the engine went pop. hopefully i will clean it all up for the WA transport department inpection to transfer to wa plates (noooo loose the qld plates sniff) then give a few fun runs around town then put it up on jacks... it has to be finished by october 1 next year for a mates wedding. will be doing cerimonial donuts insted of confetti
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
