  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i have lived without aircon for a few years... yeah you sweat a bit but oh well. its good though with the sunroof off. windows down and the sound of a screaming RB. sorta takes away the heat. well for me it does.
bah thats easy way out..
try middle of the day.. in the middle of summer.. 40+ degrees outside.. windows up, 3 passengers in the backseat as attempt to get traction to do 0-100kmh gtech..
black car is great as sauna :(
