  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
which day you going?  I'll depart nagoya at 6/feb :)
Will I'll be there from 2-9th feb, mostly up the north islands for lots of snowboarding, but venturing down to tokyo/osaka for a few days to check out the car scene (and buy some cheap bits!)
How long are you over for?
I'll arrive at nagoya tomorrow night, then first half week is at tokyo for TAS, then off to sapporo to get frostbites for a week. Back to nagoya after that and just relax for the rest of the time. looks like Up Garage stores for 2nd hand stuff is worth a visit, autobacs with retail price are about the same as order stuff from here.
so about 3.5weeks at japan I guess..
gf went to snowboard trip at nagano few weeks ago, where winter olympic held years back. Looked like lots of snow too so you wont b disappointed if you are heading north. :)
ed, also if you can stretch your visit time at japan, see if you can goto osaka auto messe..
http://www.automesse.jp/contents/2005.html
11/feb to 13/feb
its more tuning parts specific than just typical auto rice salon I guess :)
cant streach that far :P ahh well... I hope to get to TAS next year.... so i'll just have to wait!
I'm hooking up with a friend of mine to take me around a few workshops in tokyo/osaka..... she's also checking out some bits for me :)
that would b cool, I'll probably b going to auto messe if I goto japan next time depends if gf is still there or not.
well I'm all packed and theres no room in suitcase to take those race queens back, stupid winter clothes :)
um, no..
He was after $5k for his.. but its not worth that.. $3k i reckon he'd take.. its a GXE (the more luxury spec)
p.s. this is the one I'm buying: http://www.skylinesaustralia.com/forums/sh...ead.php?t=59664
i know i *was* after a wagon.. but silvertop RB20det and manual.. and the plush pimp interior is hard to go past. Something different.
The thing with a wagon, its one of those useful things some of the time, fun some of the time, but rest of the time it's like driving a boat :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
