  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Click your right mouse button on "Download Now" and select Save Target As... or Save As...
If you use Firefox: Drag & drop the "Download Now" link in a new tab (with Firefox).
Or try to copy "Download Now" link to Clipboard (Windows OS) and then paste it link to Browser Adress Bar and the Enter or press Go Button.
