  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well my day will start off with general admin work till my tray is full, then take files to and from court rooms to our paralegals for court cases, then back to the office for 15-20mins for lunch. Then more admin work till my tray is full again, then back to the court rooms till bout 30mins before i finish for more admin work and post office run and finish.
