  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
chris,
But I have heard at least three instances of where it has been mispronounced in the lyrics of music which kind of rules out the poorly educated bit. I hate the fact that I've learnt to live with poor spoken english to the point where I barley notice when people finish their sentences with preopsitions. (my most hated instance of poor english)
I was also reminded of how much slang I speak the other day when I was eating dinner with a couple who both spoke english as a second language.
chris,
I was the word fu(k and c^nt too much :P
Altough I do live in the sticks, and are muzza
chris,
I guess if you are hearing instance of mispronounciation in music, it would be from a songwriter trying to find an appropriate rhyme meter for a lyric. And so the corruption of the language continues unabated.
no.. americans are just ignorant ****ers.
I read some of his ruckus on the M5forums - One of the many forums spammed with this rally b/s. :)
I've been meaning to google search a bit more.
He's an ex hacker... Got busted hacking CIA, NASA, et al... Bargained with the US gov to "fix" their systems to avoid jail, and then went on to start an internet security company that he later sold for many millions of dollars...
The rest, as they say, is history...
He f**king rocks in the Gumballs... Always finished in the top 3...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
