  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I am calling for a law to clothe all pet animals seen in public.. Just the otherday I saw a German Sheppard as naked as the day it was born! I could even see his "rude bits" - I am simply shocked and appauled.
We can call it the "animal nudity decency act 2005 - bylaw #53232-3AD, subsection 2, paragraph 5, sentence 6, word 3" !
I too have been mortified by the lack of morality displayed by these animals, so yes I whole heartedly second that motion
Actually Charly.. have you been sniffing that ajax again?.. there is only one thing that can explain that crooked nose Mr Candy Man!!
Oh I see you're suffering a case of amnesia. Are you forgetting the pictures I still have of you from our little thailand trip?
Actually you might, you did get pretty wasted that night.
Remember our little agreement, what happpens in thailand stays in thailand.
OK next by-law is in relation to the disgusting prevellance of phallus shaped vegetables...lets ban the sale and distribution of anything with dimensions that could be construed as non-square or non-round.
Anyone second that notion?
Yes I second that motion, on the proviso that phallus shaped vegetables can be imported from another constituancy direct to a rate payers home in a Brown paper bag if a rate payer so requires.
I as a "hot woman", understand that some of my less attractive female peers may not have the opportunity to form a "relationship" with men of your caliber and may have to resort to other means for gratification. And it would be negligent of me not to take that into account.
:) boy, this is getting too hot in here.. I think I am going to have to take off my clothes and pleasure myself with a pineapple..
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
