Will anyone second that sandwich?
I will second it, IF it does not include any vegetables of the banned variety... i.e "including but not limited to"... carrots, cucumbers, zucchini, turnips, beets, parsnips, potatoes, radishes, corn, eggplants, rutabagas, sweet potato, kumara, yams, radicchio, okra, gourds etc etc
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I say we be even more obstructive and irrational. I think we should only ban those aforementioned phallic vegtables in their whole form. Therefore once you cut them in half they're perfectly legal.
The less sense it makes the funnier it will be for us. Think of the wave of angry letters from all the pensioners we'll get. :)
I will second that, IF and only if, the banned vegetables are prepared in a constituancy outside our own and imported in at great expense to the rate payer. My, and the female voters of this constituancy safety, is of the utmost importance to me and I cannot in good conscience allow a society of predatory males wandering the streets fresh with the image of phallic vegetables in their mind.
I, as an "extremely attractive woman" am constantly approached by lustful men and am fully aware that they do not need any further provocation by having these "lurid vegetables of the devil" waved in their faces day in day out.
Maybe we should actually form the interim sanctioned "Woman Against Phalli Association" this would help increase grievences against local greengrocers.
Protecting Greengrocers???
Please don't get me wrong, I mean I like "down a dirty, tie me up, watersport, nasty DVDA, sperm receptacle, bestial, unsafe group sex" as much as the next girl.
However, I cannot countenance the spending of hard earned council funding on protecting these filth peddlers. If they want to profit on the misery of women then they should use those profits to hire security to protect themselves.
I vote we stop Hansard recording at this point in time to discuss the alleged fund embezzling allegation.
Councillor Predator have you forgotten our additional *off the books* council funded retirement fund? I believe the councillor in question was transferring funds into said account.
Less said the better *taps nose*
I second that motion.
And may I reiterate for the minutes while speaking in verbatim about a proposed by-law to extend the opening hours for all local 'Mr Minute' outlets. Key replication & re-heeling has become an extremely neglected social aspect, and we must bring it up in our new agenda.
In furtherence to the Greengrocer issue
I have been offered a position on the Board of Directors in Company Chain of Greengrocers in another constituancy after my life in politics and a controlling share now. I therefore think it is in the ratepayers best interests to buy all our prepared vegetables of the banned variety from this chain of Greengrocers.
I suggest this only to save the rate payers a costly and exhaustive search for appropriate vendors from another constituancy.
In addendum if I actually lived in this constituancy, the rate payers would benefit from the arrangement with the return of rates paid by me into the council coffers.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
