  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Scene: Brian and Dominic stand around looking at an engine in pieces. Things look grim.
Vin: Looks like your ride is truly hosed O'Conner. Don't look like you're gonna get that bucket of bolts ready by tomorrow.
Walker: hey Dominic, pass me that giant packet of zip ties.. I think we have hope yet!Maybe I still will get to rebuild my 2 second car and screw that girl by the end of the movie
Dominic Looks confused...
I want to see zipTie's in F&F3..
i reckon get rid of the smoke and mirrors and get back to what its all about....fastening your intercooler to your car with zip ties....using a screw as boost controll and fixing bog to half your bar to make up for all the chunks taken out on shit roads. Now thats what we want to see.....
Bwahahah... That's gold... Forward it to Hollywood now!
I want to also see in F&F3.. when they go off on a big secret meeting in an industrial area and yell "we go live in 5", they all get lost and follow each other different ways.. Some end up at each other's houses, some end up heading towards another state, and total chaos ensues.
Your computer is telling you something !slide...
i were trying to battle with smooth but in the creation it got out of hand and increased the pic size by 7000%
i got dual amd 2600 mp's and it was still crying my gig of registered geil was all used up
i should turn it into a virus :wassup:
:cheers: "we go live in 5" wat a classic
That too, is gold...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
