  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I put it to the hourable member of P51,
that it may be in the best interests of the rate payers for her to drive around in the "white, air conditioned, turbo-charged council vehicle" at councils expense until such time as the committe for the reallocation of summer heat has found a suitable arangement for the redistribution of excess temperature in the electorate..
Ahh councillor Hottie... If only you knew...
I put forth the motion for councellor members to purchase a Air Conditioning unit for Council Member P51.
seconded.. and also for aircondition to be repaired in Member for KnowNothing's cars also..
group buy on aircon fixups?
the honourable charly would like to know exactly how many times the member for psi has broken her airconditioner since the purchase of the white government vehicle?
Member for psi, don't be cheap. Buy us some icy poles. It's crazy hot in here.
Since you're asking I'll have a lemonade one.
I disagree...even though great deals of cash were spent, they were mearly petty upgrades, therfore the cash must still be there.
Unless the missing money has been allocated to the honourable Smooth for this equipment I found in his office-
My council provided vehicle still does not have working coils... I'm going to form a committee to discuss whether we should think about petitioning to have their repair sent out for tender.
Where the hell are the icy poles?! I demand a prompt resolution to this most urgent of issues.
Councillor Batwing, this is the second compressor thing I have bought for the government vehicle to replace the original broken one that we won't go into the story of.
Because of budget cuts, I was informed that I should purchase a second hand compressor from a "wreckers" which only lasted 3 weeks until it broke in the same manner as the original compressor.
The airconditioning in my government funded car is still functional, it just isn't functional when sitting still at sets of lights.
Attention Councillor Revhead
It has come to my attention that you may have become a victim of identity theft as per here....
http://www.skylinesaustralia.com/forums/me...php?userid=1965
As we all know the dangers inherrent in the use of the internet and the need to take care when giving out personal information, it does not however give someone the right to steal someones identity in the event such care has not been taken.
I hereby propose that the council bring the full weight of our displeasure against this identiy thief.
What say you councillors?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
