  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well it seems as we have voiced our displeasure over the identity theft and all we can do in the meantime is wait until we have a response of some sort.
Failing that, let's get tough.
The time for talking is over.
Call it extreme if you like, but I propose we hit him hard and hit him fast with a major and I mean major leaflet campaign, and while he's reeling from that, we'd follow up with a lamington drive, a car boot sale, some street theatre and possibly even some benefit concerts. OK?
Now, if that's not enough, I'm sorry, it's time for the T-shirts:
"Identity Theft Out" ... "Avatar Stealing, No Thanks" ... and if that's
not enough, well, I don't know what will be.
I also will require the urgent repair to my current government transport vehicles Air cooling system and If any members could please provide details of a government approved repair agent on the coast of gold I would appreciate said information. Also if my transport is needed for more then 3 minutes to perform the repairs i will require an approved loan vehicle of no less than 1200 KW and will once again divert funds from the bacon accounts. Due to the fact that they are very succesful at raising revenue.
councillor chris you forgot the badges
Note: this may or may not be true and Councillor Dictator's office accepts no responsibilty for his actions and or his statements made. If we have made an incorrect statement please make us aware of it and we will quickly delete the information and deny it ever occuring.
I councillor dictator will second that and I put forth a motion that we cut funding in the defect department and have job cuts for the bacon all around afterall we are making hundreds of thousands from speeding fines, why not just have the cameras??
_______________________________
One of the managers, has spent ALL day trying to work out a ticketing error. Being paid 4 times what I am.. then he comes to me once he fixed it all (10 minutes ago) and tells me he's fixed it. So I tell him to write a report to state what happened (coming from a manager, not a lowly admin person like me) incase we get audited so we can trace back what happened. He goes "but you balance them". I just laughed and said "yeah but I'm not a manager and if we get audited, I'm up shit creek with no evidence as to why it happened. Who ever allowed the machine date change (you being duty manager) is to write up an explaination to be placed with the tickets for an audit trail".. He walked away.
Erin 1 - Len 0
I ****en wish I got paid $40 an hour to sit at my desk all day and try and work out a simple ticketing error. I could have done it within an hour. But I gave it to him for the simple reason that I KNEW he wouldn't be able to do it without all my input.
GRR
/rant.
yep chilli timtams though only a tiny hint of chilli i was expecting more
the truffle ones are very nice though.
Whilst on such subject i would like to put forth the motion that morning tea at tomorrows coucil meeting should consist of the entire range of new Timtam flavours.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
