  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
there has only been a small breach of copyright of which we can get away with by bribing the appropriate authorities....and or blaming it on the pr department.
__________________
Note: this may or may not be true and Councillor Dictator's office accepts no responsibilty for his actions and or his statements made. If we have made an incorrect statement please make us aware of it and we will quickly delete the information and deny it ever occuring.
Free public transport would place our tea and scone budget in jeopardy.
I move that we should increase the cost of said public transport then when people start relying on their own transport increase tolls, petrol taxes, registration and insurance so they go back to public transport.
Creating a viscious circle.
Then we can all have limos and personal drivers
war indeed, i move that military force be used in order to stop this man from further hurting our party. Once again funds can come from the bacon and the extra speed cameras placed around blades house.
Calling all council members!
I see after the adjournment of the meeting last night, the remaining few were contacted by the identity thief. I agree war is the only option, but not via biological means...but via the gift of chilli timtams that our founder Sir Arnott has been stockpiling.
May Blade be smitten by their heat!
I declare war on your council.
 You stole my identity revhead, i want it back, and u spammed my wtb thread
Just be thankful I'm allowing you to use my "after dark" persona :aroused:
Your wtb thread was over anyway, you said you needed the PFC by Thursday and that had well and truly passed. Besides, you should feel priviledged having such esteemed Councillors as ourselves grace your thread.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
