  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Col: the coolers are cheap, but the piping is the exxy bit.
I can't find any cheap sources of piping kits around. Cheapest seems to be around $500 or so for the whole piping kit.
I've got one of the hybrid copies sitting around, its decent enough quality.
seems stupid that you're paying more for the actual "attachment kit" than the item you are attaching itself, if you know what I am saying.
That is why I believe nexus still hasn't fitted his cooler that he has had, for oh, 12 months? :(
hmm usually if you recieve a msg it would pop up on the screen but it isnt, and its not in my multimedia inbox. Bah phones
I sent it with some text and a wav file, so might have been too much for your phone all at the same time
It's true, plus don't rule out my extreme laziness
sucks that a few metal pipes cost more than the cooler. $700.00 is the cheapest for the pipes and fitting that I have found
you can do the back-around b.s. with the coolers.. back to your standard intercooler pipe positioning in the engine bay.. I might try that on one of the cars - but bit of stuffing around... got to track down mandrel bends.. etc.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
