Just sprayed some panels of the red for my car...backed off the aluminium flake content, and it looks teh bollocks :) Woohoo I love free stuff!!!!
niiice
so the car will be done by Monday then?
:rofl:
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
just ringing up metal manufacturers for piping wwork, WTF piping is CHEAP!
$18/mtr for 3 inch diametre 1.6mm wall thickness 304 grade stainless
and for the bends in 316 grade stainless:
90 degree bend $33.15 (Mandrel)
180 degree bend $64.40 (Mandrel)
So bout $100 all up for the steel, dunno how much the silicon joiners be, but definatly not $700 dollars worth!!!!
hmmm
interesting, I think that we need to be buying two lengths of everything. Should have thought of your hardware connections.
OH OH OH All of a sudden you're freindly with me eh, meh I'm over it, Marc wants some new piping too and he's got dodgy stuff but it all fits so prolly going to model mine off his and buy 2, meh was thinking about a group buy, but too much effort me thinks.
Also this is all going back to the stock piping, so dunno if that is what you are after Nex?
haha can't take pics, no camera here at work :)
I wish it was ready for Monday...I'll have to get a week off work to do the car.
I need to get some pipe too, my intercooler is too ricey sitting there but not connected.
I'm always friendly to you Ska :)
Yeah back to the stock piping is cool with me :rofl:
speaking of paintjobs
check out this one
*warning not work safe or for people of sensitive nature*
http://img.photobucket.com/albums/v421/sla...lown/1856fp.jpg
*You Have been warned so do not moan to me later*
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
