  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ooo..new look..so maybe some good will come out of this.
yeah, thats the thing motivating me to get mine fixed. If i can get the new sideskirts fitted it will make the car a fair bit different to look at, so while i already know what it looks like "non-multicoloured", have no idea how it will exactly look with the whole 400R kit. Will look a lot more consistent too.
Exactly, It will breathe much needed 'freshness' into the look of it...
I gave up getting a new TS front bar, only place that had one was Top Secret, funny that... $1200 just for the bar, then add shipping... no thanks, im only going to crack it anyway!
Im sitting here thinking about the possabilities of installing a boost guage my very self..
You see me and anythign technical dont mix, i seem to break everything i touch..
but thinking about it, i think it would be a piece of piss to install a boost guage..
simply locate a boost line, snip it in half. plact a T piece in there..
then you have instant boost reading?
then you just have to wire the rest up to something to get the lights working!
maybe i should take a shot at it!
Pity.. but guess u gotta go in with the attitude "its not a show car, i drive it nearly every day", you'll always get a few small stone chips and the like. i used to worry so much at every little scrape.. now i couldn't give a crappa..
p.s. nexus.. tried getting out the back carpark when i was leaving - no friggin chance! ended up reversing all the way back when i saw the angle.. front way i managed to get out though without a scrape so all good :D
p.s. nexus.. tried getting out the back carpark when i was leaving - no friggin chance! ended up reversing all the way back when i saw the angle.. front way i managed to get out though without a scrape so all good :)
Blame it on the Lawyers next door they think it is angle parking, or at least park like it is.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
