and, i have zero issues with street machines
i could have bought my car cheaper, but i was super happy with them (was worth paying extra);
no dramas at all, even when we had a few small problems after we got the car home;
they fixed all for nix
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
NA_R33 - Yeah took a closer look and it looks like the rack is bent as well as a whole other bunch of stuff, so I am probably just gonna tow it to Gav's and let him sort out the mess! Thanks heaps for the help changing it and offering to help out, muchly appreciated :)
Pred - Man that is a pretty intesting door you had, I really wouldn't mind hearing bout it for the 500th time, I know what it's like as I have had to explain my traffic island "incident" like 500 times this week.
ska: whole rack bent? hmm, now looking quite expensive. Steering arm is one thing, but a whole replacement steering rack is not an easy job. Feel for you man :P
nexus: me? nah, just search VIC and search for "And you thought Gordo's bad luck had ended" thread..
Yeah well, was my own fault so cant bitch and whine about it, just pay for it and get it fixed, got a car trailer and something to tow it so now just gotta wait for the replacement mag to come in and take it to Gav's :P hopefully I might have enough left over to get a cat back exhaust :D maybe........... fingers crossed :D
It was actually pretty lucky I didnt have a after market front bar or side skirts as they would probably need replacing too, I am soooo lucky I didnt get any body work damage, but guess I kind compensated with the mechanical damage. Well if you're gonna do something, ya gotta do it RIGHT! :P
yeah.. exactly - you would have done them.. all those stupid bits of fibreglass are a pain in the ass.. my replacement front bar last year: $900 . Can end up costing just as much as the damn mechnicals..
For those interested in the story of the multicolour car read here.....
http://www.skylinesaustralia.com/fo...highlight=gordo
woohoo.. now i don't have to explain it to 50 people again! :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
