I'm a tightass so use the Mobil1 SemiS stuff. Seems fine, seeing as i'm pretty hardcore on the changes on every 5k -- bit expensive $55 or so each time for the full synthetic.
SemiS is usually only $32 or so.. It does say "designed for turbo charged engines". Probably not as good for the engine as fully synthetic but my engine is still running strongly.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guys .. i need some help..
when need to start a 'find flux a friend' campeign or something .. because im so over being a loner..
im thinking of moving back to sydney because its just not happening up here..
so please feel free to donate a human to this fund preferable female aged between 18 - 25 with out any ****in mental issues ;)
please?
ill be your best friend!!
Nah i just think it is the way the light fell, here is a bigger picture... http://www.skylinesaustralia.com/photopost...&sort=1&cat=500
The Front bar now that is a different story, that is badly in need of respraying at the moment, I want to do it but I also have another veilside front bar to go on when I get the FMIC, so I don't want to get it sprayed if I am getting it replaced soon, but I am hating they way it is at the moment too.
Hmmm decisions, decisions ;)
I don't know yet,
I was thinking of keeping it "just in case" but I don't know if I want a front bar hanging around the back of the house indefinitely.
I guess I will decide when the time comes.
Why? are you interested in it?
I feel for you mindflux,
when I first left highschool I went and lived in Europe for a year by myself, man there were some lonely times there at the beginning.... but you stick with it and it comes good eventually.
Just have to have faith in yourself that you are a good person and that you have something to offer I guess.
doesn't make it easy though ;)
A female of any age without ****in mental issues is a huge ask nowadays
I blame it on reality TV ;)
now mindflux: don't go killing anybody now will you?
I should go down to DMD and pick up my sideskirts, nice day for it!
Mindflux, you sound like patrick batemen. Go and read Some Brett Easton Ellis and if you understand it on any level be very worried. and you really have to stop caring so much. Also if you're all jaded on relationships this might help clarify how women's minds work. Sorry if it's a repeat.
www.laddertheory.com
and remember if you see a guy who is clearly a dud with a really really hot girlfriend don't envy him. Pity him.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
