I'm a tightass so use the Mobil1 SemiS stuff. Seems fine, seeing as i'm pretty hardcore on the changes on every 5k -- bit expensive $55 or so each time for the full synthetic.
SemiS is usually only $32 or so.. It does say "designed for turbo charged engines". Probably not as good for the engine as fully synthetic but my engine is still running strongly.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Guys .. i need some help..
when need to start a 'find flux a friend' campeign or something .. because im so over being a loner..
im thinking of moving back to sydney because its just not happening up here..
so please feel free to donate a human to this fund preferable female aged between 18 - 25 with out any ****in mental issues ;)
please?
ill be your best friend!!
Nah i just think it is the way the light fell, here is a bigger picture... http://www.skylinesaustralia.com/photopost...&sort=1&cat=500
The Front bar now that is a different story, that is badly in need of respraying at the moment, I want to do it but I also have another veilside front bar to go on when I get the FMIC, so I don't want to get it sprayed if I am getting it replaced soon, but I am hating they way it is at the moment too.
Hmmm decisions, decisions ;)
I don't know yet,
I was thinking of keeping it "just in case" but I don't know if I want a front bar hanging around the back of the house indefinitely.
I guess I will decide when the time comes.
Why? are you interested in it?
I feel for you mindflux,
when I first left highschool I went and lived in Europe for a year by myself, man there were some lonely times there at the beginning.... but you stick with it and it comes good eventually.
Just have to have faith in yourself that you are a good person and that you have something to offer I guess.
doesn't make it easy though ;)
A female of any age without ****in mental issues is a huge ask nowadays
I blame it on reality TV ;)
now mindflux: don't go killing anybody now will you?
I should go down to DMD and pick up my sideskirts, nice day for it!
Mindflux, you sound like patrick batemen. Go and read Some Brett Easton Ellis and if you understand it on any level be very worried. and you really have to stop caring so much. Also if you're all jaded on relationships this might help clarify how women's minds work. Sorry if it's a repeat.
www.laddertheory.com
and remember if you see a guy who is clearly a dud with a really really hot girlfriend don't envy him. Pity him.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
