  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well raced home and put the three wheel'd beast out for collection tommorrow morning, also stuck the stickers on, BEWARE MJ the small ones are not directional, although I did make mine that way after a bit of fiddling, I was going to bring the digicam home rom work, but left in a rush to get to the tyre shop to pick up my mag that I forgot it, and then when I got there they were closed anyway !!!! :cuss: Bah hope they are there right on time in the morning other wise I'm gonna be late for work , grumbles.....
yeh i had a bit of trouble putting the little ones on its hard to line it up against the red background bit, this set i got today is my second set. First set got water damaged and was farked so i hope these turn out good. Yeh i also noticed they both are identical and will be opposite ways on the side of the car but it doesnt bother me. Did u put urs in that little 1/4 panel glass? i reckon they look the best there. I also got the big one up the top of the rear window
i got mine just on the door below the mirror on the passenger side. It's cool, because you can actually see people when they are checking out the sticker :)
I've seen quite a few people check it out -- probably wondering what crazy street racing gang I am part of or something. Its funny, especially the old codgers.
Yupp same places, except I altered the small one on the passengers side, put the red rings on upside down, so that they face the front, and then put the bottom writeing on to fit and then moved the top writing in to close to the red rings, looks sweet as :)
I have my car back..... phew
It is running all nice now and I can stop soooo much quicker now (go the slotted rotors)
Plus had time to sit down with Gavin and start on a roadmap for 250KW at the rears :)
dyno day?!
im in .. i wanna see what figure my car currently makes as its the same since ive purchased it. so i can work out a goal figure that i want to reach
and pluss i wanna hopefully get a bigger figure then my bros r33 so i can rub it in :) (even though i know i wont)
but hey im dead stocker, but ill be in
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
