  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
speaking of computers..
when i first moved up here my graphics car wouldnt work right (still doesnt) so i jumped down to FS computers on the GC highway
and the dude stuffed around for like an hour and couldnt figure out whats up with it, anyway he calls me into the back and says look it seems ok in away bla bla bla ... opens up my pictures and says here we will just open this picture to show that the graphics are still good. (oh pririor to this i had to tell him my password was 'goat' at the time and hes like 'haha ive heard funnier ones)
but yeah so he opens the pic and just as he clicks on it .. i realised it was a full screen shot of your belovered hello.jpg
and i almost had a heart attack when he clicke don it thinking this guy is gonna pass out when this loads or something, (dunno hello.jpg? maybe you should check out HTTP://GOATSE.CX) :):D:)
the poor guy was speach less and i was so ebaressed thinking .. this guy is gonna think im some weirdo or some shit
lol.. mine just came with the car so no idea whether they are doing any difference, thats all :D Seem to stop me nicely enough, but still get a bit of brake fade after heavy use.
My rear tyres are starting to get fugged though so brakes probably aren't the biggest stopping concern on mine.. got a lot of life out of *those* tyres :) 15,000 I reckon if I'm lucky.
that has to piss u off, james ur car aint loud at all, i got gt radials, cheaps tyres and i got like 35000 out of em i think which i though was pretty good, mum only gets like 27 out of expensive bridgestone things but shes a nut.
I only got 15,000 out of my dunlop lm702's 255's...
Not entirely happy with that...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
