  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yo Dude.
I have a TD06-19c On my RB20DET, Its internal wastegated and bolts straight onto the stock manifold with a 10mm spacer plate (to avoid rubbing the block).
They dont have water lines at all as they arent water cooled. You would wanna get the oil feed and oil return lines with it to save hassles.
As for price that isnt too bad. I am selling my Td06-19c, dump pipe, silicone outlet pipe, braided oil feed, oil return, spacer plate, intake pipe etc etc complete bolt on kit for $1600 :P
They are decent turbos. Tho you will have a bit of lag... its all fun and games once on boost ;) my 255/40/17's manage to light up on boost
i think mine is rated at around 440hp, i think the 17c would be slightly less than that. Probably different sized housings.
I am running the 8cm2 housing, also have a spare 10cm2 housing. I think the 10cm2 housing is equivalent to a .63 AR .... ? not 100% sure, i think Steve posted a comparison a while back.
Oh yeah mine was converted to internal wastegate too. I think The TD06 is naturally an external wastegated turbo. But i noticed with the latest line up of TD06-20g's they have internal gated versions
skyrine dave - i didnt tell you the price :P .. what price were you thinking i was paying?
how does turbo lag actually work, i think i have a standared turbo on the skyline (i cant even find it) and it hits boost at 3 grand
like i seriously know nothing about turbos so .. is this turbo good, or wheres it ranked in the turbos .. like double the size as a standard t28 (i think thats what mine has got)
i am pretty sure i got 300hp@wheels at the moment.
I have a dyno here with 270hp@wheels on 15psi@5000rpm... 10psi@6000rpm... big Boost leak in the outlet pipe (was radiator hose, now silicone).
So i assume with the same 15psi (or more) and 7150rpm rev limit i would see 300hp.
*when i put silicone hose on after that dyno i hit, and ran, 18psi. Nothing else changed. Felt great :P
EDIT: for Mindflux... thought i saw $1500 somewhere... musta been someone elses post ;) my bad
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
