  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
You don't know frustration , just sit back and listen to this .
I have just brought my new line 4 weeks ago while it was on it's way over fro JP
it landed last thrs , found out yesterday it has JP funge , so it's another two weeks so get cleaned and sprayed , then I have to wait another two weeks for it do get resprayed , which does not matter as I HAVE A BROKEN ANKLE AND CAN'T DRIVE . but it should all be sweet in about a month , new car good ankle and ready to rock , hoping I can make it to the opening of Qld SAU club , whenever that happens
i had to wait for delays when i imported my car,
i now have to return my car to stock to pass a defect, i have to pay to have my manifold studs replaced and all the stock gear put back on just to shut a damn exhaust leak up so that they dont go "whats that loud ticking noise"
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
