ben, be more specific. Oh, do you remember that VL commodore crash a few years ago where the car was totalled? You know the one? Where he crashed. In the commodore? The one he was driving? driving on the road?
Also for some reason I've had a spate of w@nkers who think they can race me lately and for some reason they've ALL been holdens. Go figure.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Okay what about this....
"Every cloud has a silver lining"
"There is no black and white, only shades of grey"
"A bird in the hand is worth two in the bush"
"Fail to prepare, prepare to fail"
etc, etc
etc, etc
lol....nah, they're just cheesy cliche's :D
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
