  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
yeh its ment to say no trees, not new trees. i hate it, if i wanted to live with old people id live in a home. they had the cheek to ask me not to run the car for so long at night.. they got a rather nice finger and "if i dont run my car, you can give me $10k for new turbos, and a day with my lawyer" they seem to hate me now. i duno why LMAO.
they had that system at school the teachers computer had a program on it and could see everyones computer and control what they were looking at
Yeah we have that it is called VNC and comes in a massive range of different flavours, basically it allows me to full take control of any users computer,great when a user needs a printer installed or is having problems, saves me from getting off my lazy ass all day :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
