  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Morning, and true about vnc, only thing is I prefer terminal services, now with microcrap's new remote desktop client, it is just way faster than any flavour of vnc I have tried, but hey vnc rocks for free! It is great cause I setup my mates computers and thier firewalls so whenever they have probs I tunnell though their firewalls and just take a look see :P Also sometimes take control and do funny stuff :D
Also, I can highly recommend Broadwater Brakes & Suspension as of this morning...
They fitted and balanced my Azenis to my rims in under 45mins for $20... I got there at 8.10am and asked if they could do it while I waited...
I was well looked after, undercharged (IMO) and would have no hesitation going back...
thanks strutto.. may keep it in mind. I'm going to be down the GC a fair bit. Won't be long before i'm moving down there i guess.
knore: you gotta go all the way to the f.ucking airport to pick up something that is *sent* to you? What a scam.. bloody terrorists, bloody sales tax, bloody bloody.
Hey Charly can you pick these lyrics, one of my fav bands :(
Give me the keys now you're too drunk to drive
You say it's all because of me
Tilting your head so you can catch my eye
Promising things I can't believe
Go the punk:
Would it make you feel much better
If it was you against the world
If you were an alien
If it were conspiracy
And would it hurt to live in comfort
If you found someone to trust
If you knew that you were with us
If we shared a common goal
But you will isolate, alienate
No one can appreciate
The poor miss understood
Can you see that I don't care anymore?
Do you ever stop to listen
Are you a martyr for your pride
Does it makes you feel much better
When you are an alien?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
