  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
We sell the occasional projector, that would be about the only HTPC stuff that I can recall
OK...didn't realise you sold A/V type stuff, thought it was just PC hardware
I was an A/V tech for 8 years before a recent career change
kahoots? :) Umart sells a few TV tuner and capture cards that can perform as a PVR. The leadtek is meant to be a good card for the price. Depends what you're after - the digital TV encoder cards are probably the way to go, but only just starting to hit the market.
~$200 that gets you a digital TV tuner and all the standard PVR stuff sounds like its going to be the way of the future.
..well its inevitable that a topic about "who is best out of betty and wilma" and cartoon characters is only going to go into bad territory.
What sort of a/v tech stuff? private home theatre, industry stuff or ? my old man is a bit of an a/v tech himself in melb actually.
