  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Gotta love working with computers that are attached to really really really big saws :) Guess the guy who designed them thought, hmmmm where can we put this computer, oh yeah I know right in the middle of it, underneath and lets make the IT person have to crawl on back to get to half of it and climb all the way through it t get to the top half! got saw dust all over me now
anybody got $1000 lying around.. good deal for a powerFC
For sale; Apexi power fc and hand controller for the rb25det.
Is in perfect condition and has just come out of my 33gtst,
3 weeks ago. Selling because i have just sold my gtst and have
just bought a 33 GTR V-SPEC so i have no use for it.
Asking price is: $1100 ono.
hmm ... ahh: "HEAT6" yeah.. heard of that one. Bit stupid using HEAT plates isn't it seeing as you know exactly what to look for?
I pretty much check for any Falcon or Holden these days for the obvious signs. Get some dirty looks from most Falcon and Holden drivers in new cars as i'm pretty much always gawking in their window as i'm travelling along :(
