  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
John, yeah lots of coffe works well as i have "management training" on fridays, so I had hmmm lets see, bout 11 cups of strong coffe now i am ALL HEPPED UP AND RARING TO GO! but got nothin to do....... and wtf is harry's mindflux?
Harrys is a Diner at Newmarket which old school hot rods go to as well as muscle cars (imports aren't really welcome, but you just park around the corner).
It USED to have heaps of skids and stuff. Harrys is such an old meeting spot. I used to go there when I was 13.. so that's like 7 years ago! It used to be bigger back then. When v8's were still cooler than schooler
Hmmmm going somewhere where I have to park around the corner, bah that sucks, I take pride in my car and would want to drive it there, but as i am as skinny as a rake and am as yella as a lemon, I'll pass :)
Got any ideas john/mindflux?
ska - yeah ill cruise the coast if i dont get a better offer .. havnt heard back form the only 2 people i know on the coast :) .. but i think there both going clubbing and i guess i dont really wanna
so ill be happy to cruise, some spots we could do is..
Natural Arch (glow worms) .. kinda boring though
Currumbin rock pools (glow worms) .. thats normally a pretty cool drive ..
we could do a few laps thru surfers (please look after me car gods) .. and then maybe head down and go thu tweed, palm beach
i really dont know my directions but thats all off the top of my head :D
Nope i dont have either's phone numbers, MJ would definatly be in, too bad nex would prolly be in too, i dont have a mob so they couldnt call me after we down there either, bummer MJ would definatly wanna come as he has tomiss the thurs meets cause he works!!
Welll.......... hmmmmmmmm
Na r33 - ill drop you a PM with my mobie ...
ska .. you meet john (is it john .. i cant rememebr your real name bro) .. at the bp.
and let me know what time you guys are heading down .. and i guess i can meet you guys at BWCP and we can do a few laps thru surface, and we can discuss other stuff when is e eyou boys
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
