  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ska: whats your warehouse? and what does sort of stuff does it have? for future reference. Don't really need any tyre polish stuff atm, i just had some in melb but left a lotta crap down there.
yamutha: feel sorry for you .. I'm going out tonight to get blasted so hey :D
But your not the only person that generalises everyone from boostcruising. There are wankers and I'll admit that. Any website/club has it's wankers. Hell even this section does. BUT I don't generalise everyone is this forum for being "loosers" just because one or two are idiots..
Just shits me, me being a member since the site began, that *WE* being sensible moderators of the site, get called "loosers" becaues of one or two people's actions.
Yeah...I understand. it just seems that every second thread is a tail of woe about being hassled by the cops, losing their cars or licences or getting into a fight.
It was meant to be a play on words rather than a direct insult directed towards boostcruising.
I'll try to be a little more PC next time.
Apologies once again
Its a $2 chain of stores, like "Crazy Clarks" "Silly Sollies" "The Warehouse"
It sells all manner of things imported from china, everyong is made in china and usually cost no more than $5.
HEAP of crap you can buy there, heaps of it cause The Warehouses are usually _HUGE_ and they are scattered all over the place.
I havent had the need to even bother with boostcruising, they might be good, but SAU has contained all the information I have ever needed, and had more than enough great people here to help me out, so why look else where?
I am not saying BC is good or bad, just never had the need to look there that's all :D
My 2c worth
Problem with text is that it is not emotive enough, one sentance could be read by several different people and mean to them several different things, depending on thier mood. Would have loved to see the original post though can you pm it to me?
im affiliated with both, i some times attend boostcruisings website too look at photos here and there, but thats about it.
From my experiences with boost cruising i had found that there cruise organising has been no better then hopelessly useless..
Im not going to start an argument or anything.
by my 2 cents are simple. I find boost cruising useless when it comes to event organisation
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
