  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
believe it or not i did a full pass with the underbodies on, it got mixed reactions but i know what u meen most people are very performance orientated and kinda against rice.
*Stands in corner*
Actually I think they look awesome. They looked pretty cool in that video you had.
cheers mate, it gots a while to go yet but its getting there slowly. Do a bit save some more, do a bit save some more etc, im in the save some more stage, conversion left me completely broke, cause 2 nice people told me they wanted my enigne an then decided against it.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
