  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahaha thanks for the tip :D
i do like my car to look good though, but not too over the top.
If you can find a good combination of a simple bodykit, nice wheels and small thiings that make that difference like clear indicators, painted calipers, tints etc then when all put together will look really good and get plenty of looks and attention.
I made a new boot for my gear box yesterday looks pretty cool, I am going to start doing the rest of my interior myself in white leather :D
Not sure if I should paint the dash white also?
What do you guys reckon I was thinking just doing the door panels and getting the seats done.
ouch... me bleeds to death slowly..
That can look great with the white leather.. if you've got the time go for it! White dash would look good too I reckon, if you clear coat it and things should come up really nice. Add some EL dials and should look much more modern.
can you retrim interiors? so you are gonna do your seats and doors?
that would look rank, ive always liked white leather but hard to keep clean. I wouldnt paint the dash bits white though, as i think it looks a bit cheap when contrasting between the leather and the black console pieces
I am going to get someone else to do the seats but will do the little things like trims.
Will see what it looks like before I do the dash, will be a while before i get the seats done though. Will probably just get some white seat cover for a while, Do you know where I can get some, like the snap-on style ones i have seen around?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
