  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hahaha thanks for the tip :D
i do like my car to look good though, but not too over the top.
If you can find a good combination of a simple bodykit, nice wheels and small thiings that make that difference like clear indicators, painted calipers, tints etc then when all put together will look really good and get plenty of looks and attention.
I made a new boot for my gear box yesterday looks pretty cool, I am going to start doing the rest of my interior myself in white leather :D
Not sure if I should paint the dash white also?
What do you guys reckon I was thinking just doing the door panels and getting the seats done.
ouch... me bleeds to death slowly..
That can look great with the white leather.. if you've got the time go for it! White dash would look good too I reckon, if you clear coat it and things should come up really nice. Add some EL dials and should look much more modern.
can you retrim interiors? so you are gonna do your seats and doors?
that would look rank, ive always liked white leather but hard to keep clean. I wouldnt paint the dash bits white though, as i think it looks a bit cheap when contrasting between the leather and the black console pieces
I am going to get someone else to do the seats but will do the little things like trims.
Will see what it looks like before I do the dash, will be a while before i get the seats done though. Will probably just get some white seat cover for a while, Do you know where I can get some, like the snap-on style ones i have seen around?
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
