  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Yeah right, so how do you think the semi-slicks will go tonight ? :( Also I'll volunteer to be last again :) but hopefully you guys will hear my pleas of directions or to slow down.
Prolly wont need the buddy system onyl a couple of roundabouts to go through :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
