  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Don't pay it Cyrus, just do a sticker up in photoshop and stick that in the windscreen.....
It will fool the coppers I give you a 100% guarantee
(this is not a guarantee)
Gordo's the chop wiz, might get him to do me upa rego stick while he's there tomorrow, you wont mind would you? :(
Good thanks Cyrus
have'nt changed both yet so I have my old one which is ultra white and your new one which is normal yellowy colour
My car is like David Bowie i.e has two different colour eyes
Well he could if you want it done in black and white :)
no frivolous expensive high faluting colour printers for us
lol.. dodgy stickers would take an hour to make :( then again they would have their uses.. now if only you could also make up fake number plates
*cough*
http://www.sign-fx.com.au/store/browse/6ee...5f43cd4f,,.html
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
