  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Don't pay it Cyrus, just do a sticker up in photoshop and stick that in the windscreen.....
It will fool the coppers I give you a 100% guarantee
(this is not a guarantee)
Gordo's the chop wiz, might get him to do me upa rego stick while he's there tomorrow, you wont mind would you? :(
Good thanks Cyrus
have'nt changed both yet so I have my old one which is ultra white and your new one which is normal yellowy colour
My car is like David Bowie i.e has two different colour eyes
Well he could if you want it done in black and white :)
no frivolous expensive high faluting colour printers for us
lol.. dodgy stickers would take an hour to make :( then again they would have their uses.. now if only you could also make up fake number plates
*cough*
http://www.sign-fx.com.au/store/browse/6ee...5f43cd4f,,.html
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
